Σύνθεση μικρού φ/β
Καλησπερα,
Θελω να φτιαξω ενα συστηματακι το οποιο θα φορτιζει μια συσκευη που λειτουργει στα 3.7 volt.. (Εστω κινητο).
Ψαχνωντας βρηκα αυτο το φ/β
 https://www.aliexpress.com/item/Portable-Mini-6V-0-6W-S-olar-Panel-Power-Poly-Module-DIY-Small-Cell-Charger-Solar/32738823484.html?spm=2114.01010208.3.19.3T1c1V&ws_ab_test=searchweb0_0,searchweb201602_6_10065_10068_433_434_10136_10137_10138_10060_10062_10141_202_10056_10055_10054_128_10059_10531_10099_10530_10103_10102_10096_10052_10144_10053_10050_10107_10142_10051_10106_10143_10526_10529_10084_10083_10119_10080_10082_10081_10110_10111_10112_10113_10114_10078_10079_10073_10070_10122_10123_10120_10124-10050_10531_10120,searchweb201603_7,afswitch_1_afChannel,ppcSwitch_3,single_sort_0_price_asc&btsid=6b1bca26-df49-4272-9a58-b7a448f1db10&algo_expid=0d9f2384-8285-4a0d-a358-700e72516180-2&algo_pvid=0d9f2384-8285-4a0d-a358-700e72516180
Αυτο το charge controller
https://www.aliexpress.com/item/6V-12V-10A-Auto-Solar-Panel-Charge-Controller-Battery-Charger-Regulator-PWM-Hot/32769930226.html?spm=2114.01010208.3.29.nwTxKJ&ws_ab_test=searchweb0_0,searchweb201602_6_10065_10068_433_434_10136_10137_10138_10060_10062_10141_202_10056_10055_10054_128_10059_10531_10099_10530_10103_10102_10096_10052_10144_10053_10050_10107_10142_10051_10106_10143_10526_10529_10084_10083_10119_10080_10082_10081_10110_10111_10112_10113_10114_10078_10079_10073_10070_10122_10123_10120_10124-10120,searchweb201603_7,afswitch_1_afChannel,ppcSwitch_3,single_sort_0_price_asc&btsid=e525a131-8bdf-48f2-99d2-0226ae805cc5&algo_expid=c1d986e5-219b-4d2b-a399-2b579839d2d3-3&algo_pvid=c1d986e5-219b-4d2b-a399-2b579839d2d3
και εχω αυτες τις μπαταριες οι οποιες ειναι 3 και οχι 2 που δειχνει το link.
https://www.aliexpress.com/item/1x18650-Rechargeable-Batteries-not-AA-battery-3-7v-2200-mAh-Lithium-Li-ion-Battery-With-Tip/32498952594.html?spm=2114.01010208.3.11.pLWmvK&ws_ab_test=searchweb0_0,searchweb201602_6_10065_10068_433_434_10136_10137_10138_10060_10062_10141_202_10056_10055_10054_128_10059_10531_10099_10530_10103_10102_10096_10052_10144_10053_10050_10107_10142_10051_10106_10143_10526_10529_10084_10083_10119_10080_10082_10081_10110_10111_10112_10113_10114_10078_10079_10073_10070_10122_10123_10120_10124-10119,searchweb201603_7,afswitch_1_afChannel,ppcSwitch_3,single_sort_0_default&btsid=df1d126b-72c0-41fb-9f8a-4475b0466c35&algo_expid=5b5b7113-d735-47b0-9124-5c81838f69ac-1&algo_pvid=5b5b7113-d735-47b0-9124-5c81838f69ac
Μπορει καποιος να με βοηθησει στο αν στεκει το συστημα αυτο , αν θα κανουν κανα μπαμ οι μπαταριες, αν θα γινει υπερχειλιση, αν πρεπει να γινει παραλληλη ή σε σειρα συνθεση των μπαταριων κ οτι αλλο πιστευετε οτι ξεχασα??
Το ολο σκεπτικο μου ειναι να φορτισει η συσκευη που δουλευει στα 3.7volt και να ειναι παντα συνδεμενη με αυτο το συστημα. Αφου το συνδεσω μια φορα να μη χρειαστει παλι για αρκετο καιρο πειραγμα. (Η συσκευη χρειαζεται 1000mah ανα 7-15 μερες)
Ευχαριστω
Όχι δεν γίνεται.
Οι μπαταρίες είναι ιόντων λιθίου και (για λόγους ασφαλείας) πρέπει να φορτίζονται με κατάλληλο φορτιστή.
Ο ρυθμιστής φόρτισης που δείχνεις είναι εντελώς ακατάλληλος για να φορτίσει με ασφάλεια τέτοιες μπαταρίες.
...  Μπορει καποιος να με βοηθησει στο αν στεκει το συστημα αυτο , αν θα κανουν κανα μπαμ οι μπαταριες, αν θα γινει υπερχειλιση, αν πρεπει να γινει παραλληλη ή σε σειρα συνθεση των μπαταριων κ οτι αλλο πιστευετε οτι ξεχασα?? ...
όχι δεν στέκει.
Θα κάνουν μπαμ ή θα λειτουργήσει κάποια προστασία.
Ούτε παράλληλη ούτε σειρά.
Εν ολίγοις οι Li-Ion θέλουν Li-ion charger. Απο το site είδα ότι υπάρχει ειδικός φορτιστής γιαυτές,
Ο charger στο link που έδωσες είναι μάλλον για άλλη δουλειά.
Δεν γίνεται να χρησιμοποιήσεις το PV panel για να φορτίσεις τις Li-ion μέσω του Li-ion charger. O charger θέλει 100-240VAC για να λειτουργήσει και το PV βγάζει μόνον 6V και μόνον 0.6W. Μπορεί (ίσως) να γίνει αλλά it's complicated και θέλει εγχείριση και πατέντες και είναι και αμφίβολο.
Καλύτερα άστο.
Συμβουλή: Το Li πάνω απο κάποια θερμοκρασία γίνεται ασταθές, i.e. εκρήγνυται.
Δες το #2 παραπάνω.
Edited by AMHxaNos
