Ενανθράκωση με διάβρωση
  • Απαντήσεις 2,3k
ΟΚ είδες την τιμή.
ACI Concrete repair manual
Abstract: Published by: ACI, ICRI. Third Edition
This 2-volume set is the most complete collection of concrete repair information ever assembled. Topics include condition evaluation, materials for repair, surface preparation, application methods, corrosion management, structural strengthening, and protection methods. You’ll also get contractual guidance for measuring concrete repair work.
Sources of the more than 2,000 pages of guides, specifications, and other information include:
- American Concrete Institute
- BRE (formerly the British Research Establishment)
- The Concrete Society
- International Concrete Repair Institute (ICRI)
- NACE International (formerly National Association of Corrosion Engineers)
- SSPC: Society for Protective Coatings
There are also documents from the United States Army Corps of Engineers included in the third edition.
Contents: General
ICRI—Concrete Repair TerminologyVision 2020—A Vision for the Concrete Repair, Protection, and Strengthening Industry
Condition Evaluation
ACI 201.1R-92 (Reapproved 1997)—Guide for Making a Condition Survey of Concrete in Service
ACI 364.1R-07—Guide for Evaluation of Concrete Structures Before Rehabilitation
CS TR 54—Diagnosis of Deterioration in Concrete Structures
BRE Digest 444—Corrosion of Steel in Concrete
Part 1: Durability of Reinforced Concrete Structures
Part 2: Investigation and Assessment
CS TR 32—Analysis of Hardened Concrete
ACI 228.2R-98 (Reapproved 2004)—Nondestructive Test Methods for Evaluation of Concrete in Structures
BRE Digest 434—Corrosion of Reinforcement in Concrete: Electrochemical Monitoring
CS TR 60—Electrochemical Tests for Reinforcement Corrosion
ACI 224.1R-07—Causes, Evaluation, and Repair of Cracks in Concrete Structures
CS TR 22—Non-structural Cracks in Concrete
ACI 437R-03—Strength Evaluation of Existing Concrete Buildings
ICRI Guideline No. 03736—Guide for the Evaluation of Unbonded Post-Tensioned Concrete Structures
ACI 341.3R-07—Seismic Evaluation and Retrofit Techniques for Concrete Bridges
ACI 437.1R-07—Load Tests of Concrete Structures: Methods, Magnitude, Protocols, and Acceptance Criteria
ACI 364 Technical Notes (FAQ)
FAQ—Carbonation of Concrete
FAQ—Parking Deck Service Life
FAQ—Cracks in a Repair
FAQ—Hydrodemolition for Concrete Removal
FAQ—Alkali-Aggregate Reaction
FAQ—Surface Bruising
FAQ—Corroded Reinforcing Steel
Concrete Restoration
General
ACI 546 04—Concrete Repair Guide
Spall Repair, Overlays, and Full-Depth Replacement
ACI 325.13R-06—Concrete Overlays for Pavement Rehabilitation
Materials for Repair
ICRI Guideline No. 03733—Guide for Selecting and Specifying Materials for Repair of Concrete Surfaces
ICRI Guideline No. 03738—Guide for the Selection of Grouts to Control Water Leakage in Concrete Structures
ICRI Guideline No. 03740—Guideline for Inorganic Repair Material Data Sheet Protocol
ACI 503R-93 (Reapproved 1998)—Use of Epoxy Compounds with Concrete
ACI 503.5R-92 (Reapproved 2003)—Guide for the Selection of Polymer Adhesives with Concrete
ACI 546.3R-06—Guide for the Selection Of Materials for the Repair of Concrete
Preparation
ICRI Guideline No. 03730—Guide for Surface Preparation for the Repair of Deteriorated
Concrete Resulting from Reinforcing Steel Corrosion
ICRI Guideline No. 03737—Guide for the Preparation of Concrete Surfaces for Repair Using Hydrodemolition Methods
Application Methods
ICRI Guideline No. 03731—Guide for Selecting Application Methods for the Repair of Concrete Surfaces
ACI E706 - Repair Application Procedures
RAP–1: Structural Crack Repair by Epoxy Injection
RAP–2: Crack Repair by Gravity Feed with Resin
RAP–3: Spall Repair by Low-Pressure Spraying
RAP–4: Surface Repair Using Form-and-Pour Techniques
RAP–5: Surface Repair Using Form-and-Pump Techniques
RAP–6: Vertical and Overhead Spall Repair by Hand Application
RAP–7: Spall Repair of Horizontal Concrete Surfaces
RAP–8: Installation of Embedded Galvanic Anodes
RAP–9: Spall Repair by the Preplaced Aggregate Method
ACI 506.2-95—Specification for Shotcrete
ACI 506.4R-94 (Reapproved 2004)—Guide for the Evaluation of Shotcrete
ACI 506R-05—Guide to Shotcrete
ACI 503.4-92 (Reapproved 1997)—Standard Specification for Repairing Concrete with Epoxy Mortars
VOLUME 2
Contractual
CS TR 38—Patch Repair of Reinforced Concrete—Subject to Reinforcement Corrosion
ICRI Guideline No. 03735—Guide for Methods of Measurement and Contract Types for Concrete Repair Work
Strengthening
ACI 440.2R-02—Guide for the Design and Construction of Externally Bonded FRP Systems for
Strengthening Concrete Structures
ICRI Guideline No. 03742—Guide for the Selection of Strengthening Systems for Concrete Structures
Protection
General
CS TR 50—Guide to Surface Treatments for Protection and Enhancement of Concrete
Surface Preparation
ICRI Guideline No. 03732—Selecting and Specifying Concrete Surface Preparation for Sealers, Coatings,
and Polymer Overlays
USACE TN CS MR 4.4—Cleaning Concrete Surfaces
USACE TN CS MR 4.3 ER—Removal and Prevention of Efflorescence on Concrete and
Masonry Building Surfaces
Installation
ICRI Guideline No. 03741—Guide for the Design, Installation and Maintenance of Protective Polymer
Flooring Systems for Concrete
ICRI Guideline No. 03743—Guide for the Repair of Unbonded Post-Tensioned Concrete Structures
ACI 504R-90—Guide to Sealing Joints in Concrete Structures
SSPC—Paint Application Specification No. 7: Applying Thin Film Coatings to Concrete
SSPC—Paint Specification No. 37: Waterborne Epoxy Coating for Cementitious Substrates
Performance-Based
SSPC—Qualification Procedure No. 8: Standard Procedure for Evaluating the Qualifications of Contracting
Firms that Install Polymer Coatings and Surfacings on Concrete and Other Cementitious Substrates
SSPC—Joint Technology Update No. 10: Procedures For Applying Thick Film Coatings and Surfacings Over Concrete Floors
Testing
ICRI Guideline No. 03734—Guide for Verifying Field Performance of Epoxy Injection of Concrete Cracks
ICRI Guideline No. 03739—Guide to Using In-Situ Tensile Pull-Off Tests to Evaluate Bond Of Concrete
Surface Materials
BRE Information Paper—Testing Anti-Carbonation Coatings for Concrete
Corrosion Management
ACI 222R-01—Protection of Metals in Concrete Against Corrosion
BRE Digest 444—Corrosion of Steel in Concrete Part 3: Protection and Remediation
CS TR 36—Cathodic Protection of Reinforced Concrete
CS TR 37—Model Specification for Cathodic Protection of Reinforced Concrete
NACE International—RP0187 – 2005 Design Considerations for Corrosion Control of Reinforcing Steel in Concrete
NACE International—RP0390 – 2006 Maintenance and Rehabilitation Considerations for Corrosion
Control of Atmospherically Exposed Existing Steel-Reinforced Concrete Structures
NACE International—SP0107 – 2007 Electrochemical Realkalization and Chloride Extraction for Reinforced Concrete
NACE International—SP0290 – 2007 Impressed Current Cathodic Protection of Reinforcing Steel in Atmospherically Exposed Concrete Structures
References
BRE Digest 405—Carbonation of Concrete and Its Effects on Durability—Reference only
BRE Digest 392—Assessment of Existing High Alumina Cement Concrete Constructionin the UK—
Reference only
ASCE—Standard Practice Manual for Underwater Investigations—Reference only
ACI 349.3R-02—Evaluation of Existing Nuclear Safety-Related Concrete Structures—Reference only
ACI 345.1R-06—Guide for Maintenance of Concrete Bridge Members—Reference only
Special Cases
CS TR 33—Assessment and Repair of Fire-Damaged Concrete Structures
ACI 546.2R-98—Guide to Underwater Repair of Concrete
ACI 210R-93 (Reapproved 1998)—Erosion of Concrete in Hydraulic Structures
ACI 210.1R-94 (Reapproved 1999)—Compendium of Case Histories on Repair of Erosion-Damaged
USACE EM 1110-2-2002, Chapter 8—Evaluation and Repair of Concrete Structures
ACI 362.2R-00—Guide for Structural Maintenance of Parking Structures
Επισκευες
Παιδια
απο τα περιεχομενα μπορειται να καταλαβαιτε οτι δεν ειναι ευκολο. Φανταστειτε οτι στην Αμερικη το δινεις εξετασεις για να παρεις αδεια. Το λεγαμε με τον Θαναση και γελαγαμε οτι κατι τετοιο δεν διδασκεται στην Ελλαδα. Εαν γινει δεν περναει κανενας.
Παιδια τα πραγματα ειναι απλα. Δεν υπάρχει πιθανότητα να μην βρεθει προβλημα στα παλια κτιρια. Εαν περιμενετε να βγαλετε μεροκαματο με τα νεα συγνωμη αλλα το παιχνιδι ειναι στημένο απο τους παλιους μηχανικούς και τα γνωστα γραφεία. Εγω βλεπω μονο παλια κτιρια και θα γίνει σκωτομος. Βγαινουνε αερητζηδες πήραν και ενα λογισμικό και το παιζουν θεοί. Τους ξέρω. Τελικά μέσα σε δυο χρόνια η λογική τους κτυπάει πίσω και ξεκινουν τα σεναρια και τις δικαιολογίες. Οι γνώσεις υπάρχουν, οι τεχνολογια το ιδιο, έχουμε και 3-4 εταιρειες επιθεώρησης, τα υλικα επισκευής το ίδιο. Φιλος και καλός συνεργατης του λέει του πελάτη του δεν πληρώνεις επιθεώρηση δεν σε αναλαμβάνω. Δεν έχεις λεφτά και θέλεις να φτιαξεις το καρκίνο με ασπιρίνη, πέθανε. Τι να κάνουμε εαν δίνεις πιο πολλά σε καφέδες.
Υπάρχουν πολοί μύθοι θα μιλήσω κάποια φορά. Οπως δεν έπεσε τόσα χρόνια αρα ειναι καλό ή δεν βλέπω τίποτα. Αντε να μην τα βάλω με το ταχύ οπτικό ελεγχο που στέλνουν κατι νέους μηχανικούς που ξέρουν μονο λογισμικό και βγάζουν διάγνωση με το μάτι ή ακόμα και με το 2βαθμιο αλλα οι ίδιοι λένε για ΚΤΧ και ΚΑΝΕΠΕ και μετρήσεις. Ο μηχανικός τι ακρη να βγάλει.
Τελικά υπάρχει το Ιατρικό Κέντρο και το Λαικό. Δεν λέω και στο Λαικο προσπαθούν αλλά μένουν στην προσπάθεια.
Παιδια επειδη τα έχω πάρει λιγο σήμερα συγνωμη που τα λέω έτσι. Με πήρε φίλος και βρήκε οταν εβαζε πετρελαιο ρωγμή στην θεμελειωση. Πηρε τον μηχανικό και αυτός του είπε να το προσέξει. Λες και ειναι γρίπη και θα φύγει.
ρωγμη σε θεμελειωση βάζω και κλιμακα. Να κάνουμε ενεση σε 1.7 εκ ανοιγμα? Κανουνε οπως γράφω xray θα βάλω φωτο σε λίγο.
ground radar with x-ray
όπως είπα μπορουμε να δουμε τα πάντα.
Επισκευη μονολιθικότητας στοιχείου
Παίρνω το κειμενο απο βιβλιο Ενισχύσεις /Επισκευές κατασκευών από
οπλισμένο σκυρόδεμα, Δρίτσος Η.Σ., Εκδόσεις Πανεπιστημίου Πατρών, Πάτρα 2005
1. Ενέσεις ρητινών στις ρωγμές που έχουν προκληθεί από κάποιο αίτιο (όχι από διάβρωση). Εγχύεται ρητινοειδής κόλλα στην ρωγμή με ενέσιμο τρόπο. Αυτή η διαδικασία επισκευής εφαρμόζεται σε ρωγμές εύρους 0,1mm έως mm. Από πειραματικά αποτελέσματα έχει προκύψει ότι μπορεί να επιτευχθεί πλήρης επισκευή των ρωγμών και επαναφορά της μονολιθικότητας του στοιχείου.
Το φαινόμενο της ρωγμης χωρίς διάβρωση ειναι αρκετά τυχαίο και με μικρη πιθανοτητα. Ο Καθ. Δριτσος δίνει μια μινιμουμ τιμη ο.1χιλιοστα ενω αφήνει το μαξιμουμ ελευθερο. Το βαζε επειδη κολαει με τα προηγουμενα.
Παιδια συνηθως οι ρωγμες παρουσιάζουν ενα σχημα V. Τα βάθος τους στις περισσοτερες φορές ειναι και πίσω απο τον οπλισμό. Οι ρυτίνες δεν φτάνουν πίσω απο τον οπλισμό σε καμία περίπτωση. Επίσης η πρόσφυση σε οπλισμό δεν είναι γνωστή.
Με το φτωχό μου το μυαλό πιστευω οτι μια τετοια ρωγμή δεν επισκευάζεται τόσο απλά. Διοτι
1. δεν ξέρουμε τον μηχανισμό δημιουργίας της,
2. δεν ξερουμε εαν ειναι ενεργη (δηλαδη μεγαλωνει)
3. δεν ξερουμε εαν με την ενεση θα δημιουργησουμε προβλημα αλλού.
Η ρυγμάτωση εστω και χωρίς διάβρωση ειναι η αντιδραση του στοιχείου σε μια φόρτιση ή αλλαγή βαθμων ελευθεριας. Το στοιχείο και στην προκείμενη περίπτωση το σκυρόδεμα ρυγματώνει απο εφελκυσμό. Εαν έγινε μετά απο κάποιο δυναμικό γεγονός τότε μπορούμε να υποθέσουμε οτι φταει αυτό. Εαν οχι τότε έχουμε καταστάσεις ρυγματωσης λόγω επαναλαμβανομενων φορτίων. Το φορτία αυτα εαν η ρωγμη εχει φτάσει σε μεγέθοι ανοιγματος >0.5 χιλιοστα θα πρέπει να τα βρούμε. Συνηθως βάζουμε μυκηνσιόμετρα και μετράμε για 2-3 βδομάδες. Εαν το ανοιγμα συνεχίζει να μεγαλώνει τότε έχουμε πρόβλημα που δεν φτιαχνετε με ρυτίνη.
Σκεφτείτε οτι η ρωγμη ειναι ενας τρόπος energy release η δημιουργία νεας επιφανειας (ρωγμής) εκκλυει ενεργεια.
Κατι άλλο που πρέπει οπωσδηποτε να δούμε. Ειναι οι συνδετηρες καλά τοποθετημένοι? Εχουν υποστοί μετακίνηση. Για μένα τα πράγματα δεν ειναι τοσο απλα με τις ενέσεις. Ο μηχανικός θα πρέπει να ειναι πολύ σίγουρος πριν την κάνει. Εαν υπάρχει τασικό πρόβλημα και δεν το βρούμε τότε η ένεση θα μετατοπίσει το πρόβλημα αλλού και αυτη την φορα μπορεί να είναι χειρότερο.
Καθε άλλο. Εβαλα καποια πειραματικα απο την Lafarge. Την στιγμη που υπάρχει ρηγματωση λόγω διάβρωσης σε επικάλυψη >10 χιλιοστων δεν εχουμε συναφεια.
Θα πρεπει να ξακαθαρίσουμε συναφεια υπο μορφή μετάδοσης μέσω διατμητικών και όχι συνάφεια μεσω τριβής. Η πρωτη ειναι αυτή που μετράμε στο εργαστηριο. Η δευτερη παραμένει και μετα απο ρυγματωση. Δηλαδη μερικά κομμάτια ρυγματωμένα παραμένουν στον οπλισμό. Η isostrain condition προφανως δεν υπάρχει.
Επισκευη ρυγματωμενης θεμελείωσης
Κατα τις μετρήσεις στην θεμελειωση ήρθε και ο μηχανικός οποίος προηγουμένος είχε πει για την γρίπη. Βλεπει την μέτρηση (βλεπε φωτο προηγουμενη) και μας μιλαει για ένεση. Ο συναδελφός μου του λεέι μπορέι εαν δεν έχουμε διάβρωση. Δεν εχουμε του λέει. Κανουμε μια μέτρηση παιρνουμε -305 και 5.2 στο Wenner. Ξαναλέι αποκλειεται. Του λέμε να βγαλουμε επικαλυψη να δουμε. Βγαινει η επικάλυψη και τα δυο Φ24 έχουν γίνει Φ20. Γίνεται και σκληρομέτρηση και το 420 (Φ24 StIII) είναι ΜΟ 367. Τωρα η μηχανικάρα τρελένεται. Λεει και στους μαζεμένους ενοίκους δεν ήξερα οτι υπάρχουν μηχανήματα. Μου λέει για ένεση
Η αιτία διάβρωσης στο σκυρόδεμα (δεν έχει ξεκινήσει διάβρωση οπλισμού)
Εγχύεται ρητινοειδής κόλλα στην ρωγμή με ενέσιμο τρόπο. Αυτή η διαδικασία επισκευής εφαρμόζεται σε ρωγμές εύρους 0,1mm έως mm. Από πειραματικά αποτελέσματα έχει προκύψει ότι μπορεί να επιτευχθεί πλήρης επισκευή των ρωγμών και επαναφορά της μονολιθικότητας του στοιχείου.[1]
[1 ] Ενισχύσεις /Επισκευές κατασκευών από οπλισμένο σκυρόδεμα, Δρίτσος Η.Σ., Εκδόσεις Πανεπιστημίου Πατρών, Πάτρα 2005
Του λέω δεν γίνεται γιατι εινια διαβρωμένο. Τελικά παραδέχεται οτι έχει κάνει σε πανω απο 300 κτιρια ενεσεις χωρίς μετρήσεις και δεν ηξερε για τους περιορισμούς τις διαβρωσεις. Οι εταιρείες δεν το λένε.
Τελικά φάγαμε το Σάββατο και την μιση Κυριακή σήμερα για να κάνουμε σχεδιο επισκευής. Εχουμε βάλει και μυκηνσιόμετρο και μετράμε. Θα σας πως σε λιγες μέρες.
ας μην είμαστε υπερβολικοί για τη συνάφεια
3 ΣΥΜΠΕΡΑΣΜΑΤΑ
Στην παρούσα εργασία παρουσιάσθηκαν αποτελέσματα από δοκιμες ξολκεύσεως σε ράβδους με σημαντικό βαθμό επιφανειακής διαβρώσεως (από 424gr/m2 έως 1578gr/m2).
Από τα διαγράμματα της δυνάμεως εξολκεύσεως συναρτήσει της ολισθήσεως προέκυψε ότι ο βαθμός επιφανειακής διαβρώσεως δεν επηρεάζει τις συνθήκες αγκυρώσεως της ράβδου.
Τόσο η μέγιστη αναπτυσσόμενη δύναμη όσο και η αντίστοιχη ολίσθηση δεν φαίνεται να επηρεάζονται από τον βαθμό διάβρωσης, αλλά ούτε και ο καθαρισμός των ράβδων από την επιφανειακή σκουριά είχε ως συνέπεια αλλαγή της συμπεριφοράς.
Πάντως σημειώνεται ότι το όριο που ορίζει ο Κανονισμός Τεχνολογίας Χαλύβων (350gr/m2) έχει προκύψει από την δυνατότητα που έχει το σκυρόδεμα αφομοιώσει τα οξείδια και να ανασταλεί η περαιτέρω διάβρωση του οπλισμού.
Γι αυτό, στις περιπτώσεις με σημαντική επιφανειακή διάβρωση, είναι απαραίτητο να απομακρύνεται επιμελώς η επιφανειακή σκουριά όχι τόσο για λόγους συνάφειας όσο, κυρίως, για την προστασία του οπλισμού από περαιτέρω διάβρωση.
http://library.tee.gr/digital/m1964/m1964_165.pdf
Διευκρίνιση.
Η ερώτηση του τέρρυ αφορούσε τον εκτεθειμένο οπλισμό και τη χρήση του στη συνέχεια και επί αυτού απάντησα για τη συνάφεια
Βάζω κομμάτια απο το paper διοτι υπάρχει συγχυση.
Ελήφθησαν δοκίµια ράβδων χάλυβα από αναµονές υποστυλωµάτων σε εγκαταλελειµµένο
παραθαλάσσιο εργοτάξιο. Οι ονοµαστικές διάµετροι των ράβδων ήταν από Φ12 έως και Φ22. Η
κοπή έγινε µε τέτοιο τρόπο ώστε η υπάρχουσα σκουριά να µην αποσπασθεί από τις ράβδους λόγω
κρούσεων ή τριβών µε άλλα αντικείµενα. Από την κάθε ράβδο αποκόβονταν δύο τεµάχια για την
παρασκευή δοκιµίων εξολκεύσεως. Από τα δύο τεµάχια, το ένα χρησιµοποιούταν αυτούσιο (χωρίς
να αφαιρεθεί καθόλου σκουριά) ενώ το άλλο χρησίµευε προηγουµένως για την µέτρηση του
βαθµού διάβρωσης. Ο βαθµός διάβρωσης κάθε ράβδου µετρήθηκε στο ΚΕΔΕ. Η µέτρηση έγινε µε
εµβάπτιση της ράβδου σε υδατικό διάλυµα HCl και αναστολέα διάβρωσης
(εξαµεθυλενοτετραµίνη) µέχρι σταθερού βάρους. Εγινε αναγωγή της απώλειας βάρους στην
παράπλευρη επιφάνεια της ράβδου (το αποτέλεσµα σε gr/m2 φαίνεται στον Πίνακα 1). Η ελάχιστη
τιµή της επιφανειακής διάβρωσης ήταν 424gr/m2 και η µέγιστη 1578gr/m2. Μετά το πέρας της
µετρήσεως αυτής, οι ράβδοι, που ήσαν πλέον τελείως απαλλαγµένες από επιφανειακή σκουριά,
χρησιµοποιήθηκαν για την παρασκευή δοκιµίων. Κάθε ράβδος τοποθετήθηκε σε καλούπι διαστάσεων 20*20*25cm µε τρόπο ώστε τα δύο άκρα της ράβδου να προεξέχουν διαµπερώς από τις δύο απέναντι πλευρές του δοκιµίου (Σχ. 1).
Μιλάμε λοιπόν για δοκιμές που έγιναν μετά απο πολυ καλό καθαρισμό.
Δεν πιστευω οτι στην πραγματικότητα γινονται αυτα. Επίσης το προβλημα της συνάφειας βρίσκεται σε υπάρχων ΩΣ με υψηλα δυναμικά διαβρωσης.
Αθανατη ΔΕΗ. Η κολώνα ειναι 7 χρόνων.
Ειναι φωτογραφία απο ηλεκτρονικό μικροσκοπιο σάρωσης και βλεπουμε B500c. Τα μαυρα ειναι πόροι απο την χυτευση. Για να μην νομιζεται οτι ο χαλυβας μας ειναι καλός.
Που είναι η σύγχυση?
"Στην συνέχεια, µέσα στο καλούπι διαστρώθηκε σκυρόδεµα. Σε κάθε σκυροδέτηση παράγονταν οκτώ δοκίµια: τρία δοκίµια ήταν µε ράβδους διαβρωµένες όλες ίδιας διαµέτρου, άλλα τρία δοκίµια ήταν µε ράβδους που είχαν χρησιµοποιηθεί για την µέτρηση του βαθµού διάβρωσης (καθαρισµένες πλέον από την σκουριά) αντίστοιχες των τριών πρώτων δοκιµίων, και τέλος τα υπόλοιπα δύο δοκίµια ήταν µε καινούργιες ράβδους ίδιας ονοµαστικής διαµέτρου µε τις προηγούµενες αλλά χωρίς ίχνος σκουριάς."
Επίσης όπως βλέπεις απαντάς σε "αποκλεισμένο χρήστη". άρα για να πάρεις απάντηση πρέπει να του στείλεις και email
