Αντιγράφω από το forum της csihellas:
" Παραθέτω email Που κοινοποιησα στη csihellas καθώς και στη csi αμερικης καθώς και την απάντηση τους.
Χρ'ηστες του ETABS ενημερωθείτε και θέστε και δικές σας απαιτήσεις...γιατι προχωρανε τα πραγματα και το ETABS εμεινε πισω συγκριτικα με τον ανταγωνισμό. (φυσικά δεν ζητάμε τίποτα υπερβολικο(είναι?)-πχ σχέδια)
Demand list for ETABS:
1) Design of steel members to EN1993 and not only ENV1993.
2) Assign triangular load to shell element or area. Automatic redistribution(along the height of the area object-wall) of triangular loading when area object is meshed into the elements formed.
3) Automatic generation of wind loading to EN1991-1-4 (since ALL other international codes have been incorporated in ETABS) .This is a basic function many other programs in the market include
4) Input of loads and generally member description through TABLES. This is also a basic function many other programs in the market include.
5) The command Edit-> Measure does NOT work on 3d view.
6) When using Area springs the designer cannot limit the spring to take only compression. If there is a workaround to this please let me know, or it should be included in the analysis parameters.
7) Report of base pressures when using area springs .
Άνεση Shear wall design to EN1992
Απαντηση:
1) Design of steel members to EN1993 and not only ENV1993 – This option is now added in Sap2000 v14. We plan to add this code for ETABS v12 (due by end of Summer 2009).
2) Assign triangular load to shell element or area. Automatic redistribution(along the height of the area object-wall) of triangular loading when area object is meshed into the elements formed – This option will be added for ETABS v12.
3) Automatic generation of wind loading to EN1991-1-4 (since ALL other international codes have been incorporated in ETABS) .This is a basic function many other programs in the market include – This option is now added in Sap2000 v14. We can look into adding this option for next patch of ETABS.
4) Input of loads and generally member description through TABLES. This is also a basic function many other programs in the market include. – This option will be added for ETABS v12.
5) The command Edit-> Measure does NOT work on 3d view. – This option is only applicable for 2D view in the current program.
6) When using Area springs the designer cannot limit the spring to take only compression. If there is a workaround to this please let me know, or it should be included in the analysis parameters. – User can use nonlinear Gap element and convert the combinations into nonlinear static cases.
7) Report of base pressures when using area springs . – This option will be added for ETABS v12.
Άνεση Shear wall design to EN1992 – This option will be added for ETABS v12. "
Δικιο εχεις directionless..
Αλλά θεωρώ ότι τα 1,2,3,7 είναι απολυτως απαραίτητα και μιας και το προγραμμα δεν ειναι εμπορικό (να παραγει σχέδια και γενικά γρήγορα στατικα) απαιτούμε οι χρήστες του να προσφέρει τα πάντα 'όσον αφορά την αν'αλυση και το σχεδιασμό ενός τέτοιου προγράμματος. Αντίστοιχα προγράμματα της αγοράς έχουν ήδη ενσωματώσει τις δυαντότητες αυτές(βλ. STAAD,ROBOT κτλ..)
εμενα παντως μου κανει θετικοτατη ετνυπωση οτι οι περισσοτερες βελτιωσεις-προσθηκες που ζητατε,μπαινουν κατ'ευθειαν στο πλανο της εταιρειας.
Aν δεις τι πληρώνεις όμως για να έχεις το ετήσιο συμβόλαιο συντήρησης (και να μην φεσωθείς από την αρχή όλο το κόστος της νέας έκδοσης) θα καταλάβεις ! ....
έχω παρατηρήσει πως κατά καιρούς έχουν διάφορες εντολές στο μενού οι οποίες όμως στην πράξη δεν είναι ενεργοποιημένες. π.χ. για της δεσμεύσεις στρεπτοκαμπτικού λυγισμού steel frame design---(lateral bracing) από ότι έχω δει δεν δουλεύει ισχύει;
τελικά νομίζω οτι είναι παρατημένο πρόγραμμα και από την Αμερική γιατί από εδώ σίγουρα
Σαυτο συμφωνώ Evan..ριχνουν ολο το βαρος στο SAP και μου είχαν πει απο τη csi hellas οτι υπάρχει η πιθανότητα να ενοποοιήσουν τα προγραμματα και ουσιαστικα να καταργησουν το ETABS...
Παντως είναι τραγικό ένα τόσο αξιόπιστο πρόγραμμα να μην εξελίσσεται και να μένει πίσω σε όλα αυτά που προανέφερα στην αρχή του post συγκριτικά με τον αναταγωνισμό (βλ. STAAD,ROBOT,SOFISTTIK)
