Oι εκκεντρότητες των γωνιακών μπορούν να αγνοηθούν εάν έχουμε συγκόλληση ή κοχλίωση με 2 τουλάχιsτον κοχλίες (κατά EC3)
Σε συνδέσεις κοιλοδοκών πρέπει να γίνονται επιπλέον έλεγχοι αντοχής των κόμβων τους.
Σχετικά στα βιβλία των Wardenier και Dutta
τι εννοεις.η γραμμη ηλωσης ειναι η θεση τοποθετησης των κοχλιων και δε συμπιπτει με τον αξονα των γωνιακων.
Από Ευρωκώδικα 3: Σχεδιασμός κατασκευών από χάλυβα - Μέρος 1-8: Σχεδιασμός κόμβων παραθετω:
4.13 Angles connected by one leg
(1) In angles connected by one leg, the eccentricity of welded lap joint end connections may be allowed
for by adopting an effective cross-sectional area and then treating the member as concentrically
loaded.
(2) For an equal-leg angle, or an unequal-leg angle connected by its larger leg, the effective area may be
taken as equal to the gross area.
(3) For an unequal-leg angle connected by its smaller leg, the effective area should be taken as equal to
the gross cross-sectional area of an equivalent equal-leg angle of leg size equal to that of the smaller
leg, when determining the design resistance of the cross-section, see EN 1993-1-1. However when
determining the design buckling resistance of a compression member, see EN 1993-1-1, the actual
gross cross-sectional area should be used.
3.10.3 Angles connected by one leg and other unsymmetrically connected members in tension
(1) The eccentricity in joints, see 2.7(1), and the effects of the spacing and edge distances of the bolts,
should be taken into account in determining the design resistance of:
– unsymmetrical members;
– symmetrical members that are connected unsymmetrically, such as angles connected by one leg.
(2) A single angle in tension connected by a single row of bolts in one leg, see Figure 3.9, may be treated
as concentrically loaded over an effective net section for which the design ultimate resistance should
be determined as follows:
(και δίνονται οι γνωστοί τύποι υπολογισμού της Νu,Rd)
Αυτό ακριβώς λέω αλλά και:
Όταν σχεδιάζουμε π.χ ένα δικτύωμα με γωνιακά ή έναν κατακόρυφο σύνδεσμο ακαμψίας με γωνιακά ή κάποιον αντιανέμιο σύνδεσμο είναι σωστό να σχεδιάζονται - να τοποθετούνται τα μέλη με βάση τον άξονα τους και όχι με βάση την γραμμή ήλωσης.
Το θέμα που αναφέρεις με την επιρροή των εκκεντροτήτων και του απομειωτικού συντελεστή β2 ή β3 (0.4-0.7) είναι πολύ συμαντικό επειδή στις πιο πολλές μελέτες βλέπω να μην σχεδιάζονται καθόλου αυτές οι λεπτομέρειες. Έτσι ενώ από την διαστασιολόγιση των προγραμμάτων μπορεί να επαρκεί κάποιο γωνιακό, αν μελετήσουμε με βάση την σύνδεση του ...
