Robot Μillennium της Autodesk (Robobat)
chronism
****************************. Απλά τώρα κυκλοφορεί το 2009 , σε κανένα τρίμηνο θα υπάρχει και το 2010.
Aς μείνουμε μακριά από κάθε συζήτηση-αναφορά για παράνομα λογισμικά. Ευχαριστώ
acnt
στην αμερικη κυκλοφορησε 16/04 http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=11818169
30 μερες trial του 2010 http://usa.autodesk.com/adsk/servlet/mform?siteID=123112&id=12031356
εκτος των ελληνικων μου φαινεται και πιο γρηγορο.
στην ελλαδα θα μας το φερουν κατα το καλοκαιρι για να μας τα παρουν ή λετε να μας το δωσουν δωρεάν?
οι βελτιωσεις που νομιζω οτι μας ενδιαφερουν :
Autodesk® Robot™ Structural Analysis Professional 2010 FEATURE SUMMARY Following is an overview of new features in Autodesk® Robot™ Structural Analysis Professional 2010 software in the following three categories:
- Structure modeling and analysis
- Reinforced concrete design
- Steel design
You can find more complete descriptions of all features in the Help file and the user’s manual.
Α) Structure modeling and analysis
1. User-defined Eurocode safety factors
In Job Preferences, you can now define partial factors for steel and RC design based on Eurocode.
You can use values of the factors for a selected National Application Document, or define your own values.
2. Import DXF/DWG files as a background
Load plans in DXF™ /DWG file formats as backgrounds for defining objects in the projection, cross-section, or elevation view.
3. New object types—building components
A new attribute—structure object has been added; it is assigned to typical structure elements: Slab, Beam, Column, Wall
4. Loadings
Loads on cladding distributed to nodes and panel edges, for selected objects
Snow and wind loads according to French Eurocode 1
5. Analysis
Harmonic analysis with damping
Static/dynamic analysis of membranes, and diaphragms
You can now select calculation models for 2D structure objects (panels). The predefined models of slab, diaphragm, and deck
decrease a number of degrees of freedom and eliminate vibration modes that are negligible for the seismic analysis (such as
vibrations of slabs in their planes). A calculation model contains a finite element type, a method of distributing loads on adjoining
objects; using a calculation model, you can also eliminate selected displacements inside the panel (without changing rigidity of
the system).
Improved footfall analysis
Β) REINFORCED CONCRETE DESIGN
1. Usability
2. Display prefabricated parts and openings on 3D view
3. User interface enhancement
There are new dialogs for modifying bar groups, as well as a new method of presenting data about a selected type of
reinforcement that is being modified. Using additional commands, you can change diameters of reinforcing bars, keeping the
existing spacing of reinforcement. For RC columns you can define technological breaks independently. Reinforcement pattern
dialogs and dialogs for parameterization of drawings have been reorganized.
4. Common r-bar databases
5. Check spread footing for additional loads
6. New Design Codes
New code—Eurocode 2 (EN 1992-1-1 2004/AC 2008)
Design based on the current edition of Eurocode 2 (EN 1992-1-1 2004/AC 2008) has been enabled for:
Beams, Columns, Spread footings, Slabs
New codes—NAs for EN 1992-1-1 2004/AC 2008
Regulations based on the following updated National Application Documents have been added to the design of beams,
columns, spread footings, and RC slabs: Finnish—SFS-EN 1992-1-1, Italian—UNI-EN1992-1-1 , Polish—PN-EN 1992-1-1:2008
C) STEEL DESIGN
1. Steel Connections
New common steel connection definitions
There are new common dialogs for defining the following typical steel connections:
2. Steel Members Design
New codes—NAs for EN 1993-1:2005
Calculations of steel members based on the new edition of the following National Application Documents have been enabled:
Italian–UNI-EN 1993-1-1:2005/AC:2007 , Polish–PN-EN 1993-1-1:2005/AC:2006 , Swedish–SS-EN 1993-1-1:2005/AC:2006
  • 3 weeks later...
Κωδικός Περιγραφή (Stand Alone) Τιμή ( Σύνολο () Παρατηρήσεις
Robot Structural Analysis Subscription (1 year) 475,00
Robot St/ral An/sis 2010 Com/ial Sub/ion Re/ve from Release 2009 575,00
Robot Structural Analysis Professional Subscription 700,00
Robot St/ral An/sis Pro/nal 2010 Sub/ion Re/ve from release 2009 800,00
AutoCAD Revit Structure Suite Commercial Subscription 525,00
AutoCAD Revit S. S. 2010 Com/ial Sub/ion Re/ve from release 2009 625,00
- Σήμερα μου ήρθε ο τιμοκατάλογος.Τιμές χωρίς Φ.Π.Α.
Προσωπικά δεν ξαναπληρώνω.Τον Ιανουάριο μόλις πλήρωσα ,ούτε 4 μήνες δεν περάσανε!
Αυτό θα είναι τώρα το σενάριο, πρέπει να το πάρουμε απόφαση. Κάθε χρόνο 700-800 Ε αν θέλεις να λαμβάνεις τις νέες εκδόσεις, που θα είναι μαθηματικά 1/χρόνο, όπως όλα τα προγράμματα της Autodesk.
Το κρίσιμο θέμα είναι αν θα γίνει κάποια μεγάλη αλλαγή στους Ευρωκώδικες τα επόμενα χρόνια. Αν όχι, που είναι και το πιο πιθανό, μένεις και με την τωρινή έκδοση, δεν μπορώ να φανταστώ τι παραπάνω θα έχουν οι επόμενες που να αξίζει τον κόπο για έναν μεσαίο μελετητή.
Η μάλλον τα σκάς για την 2010, με το ελληνικό τεύχος, και τέρμα πια.
Θα συνφωνήσω με paktomenos, η έκδοση 2010 φαίνεται να έχει αυτά που θα χρειαστούμε στο μέλλον (για σκυρόδεμα και σιδηρές τουλάχιστον) αλλά η Autodesk κάθε χρόνο βγάζει και καινούργια έκδοση...
Αυτό είναι πρόβλημα αλλά εγώ προσωπικά αν είχα την 2010 θα έμενα εκεί μέχρι να γινότανε καμία φραματική αλλαγή και αναγκαζόμουνα να αγοράσω μια καινούργια.
Αυτή είναι και η προσωπική μου τοποθέτηση για το Robot.
Ναι είναι δυνατό πρόγραμμα, πολύ καλύτερο από ΝΕΧΤ, Fespa, και τα αντίσοιχα ελληνικά αλλά για κάθε χρόνο αναβάθμιση αυό δεν μπορώ να το κάνω.
από τα αντίστοιχα ξένα, πως/που θα το κατέτασες?
π.χ. το sap ειναι πολύ καλύτερο ή το etabs είναι λίγο καλύτερο κλπ
αυτό το ρωτώ και σε όλους τους συναδέλφους
σε σχέση με την εμπειρία που έχουν και σε άλλα software αλλά ξένα όχι ελληνικά
Λοιπόν από τα ξένα θα ξεκινήσω από τα:
  1. ATENA (http://www.cervenka.cz/products/atena)
  2. SOFiSTIK (http://www.sofistik.com/index.php?id=2&L=1)
  3. CUBUS (http://www.cubus.ch/hello.html)
  4. InfoCAD (http://www.infograph.eu/)
Από τα Ελληνικά για σκυρόδεμα
  1. ΝΕΧΤ
  2. ......
Για σιδηρές από Ελληνικά
  1. INSTANT
Αυτά
To Robot είναι ένα πολύ δυνατό πρόγραμμα το οποίο έχει πολλές δυνατότητες και στα χέρια ενός έμπειρου χρήστη μπορεί να κάνει πολλά πράματα.
Έχει πεπερασμένα, επιφανειακά, χωρικά, έχει για σιδηρές, για σκυρόδεμα κ.α.
και σε συνδυασμό με το Revit είναι πολύ δυνατό. Δίνεις τον φορέα σου όπως είναι στην πράξη, αυτό είναι μεγάλο ατού κατά την γνώμη μου.
Μετά έχει και το Detailing για τις σιδηρές, σου βγάζει σχέδια για κοπή κ.τ.λ.
(Στο Revit Suite τα έχει όλα και για σκυρόδεμα και για σιδηρές)
Θα το έβαζα αν όχι ίσο με SOFiSTiK και CUBUS τότε σίγουρα μετά από αυτά το αμέσως.
