Autodesk Robot™ Structural Analysis Professional 2010
Autodesk Robot Structural Analysis Professional 2010 software provides a scalable, countryspecific analysis solution for the structural engineer to help analyze many types of structures, including buildings, bridges, civil and specialty structures.
Autodesk Robot Structural Analysis Professional calculates a wide variety of structures with a comprehensive collection of design codes, delivering results in minutes, not hours.
This structural engineering software is versatile enough for simple structural frame analysis or complex finite element analysis and offers smooth interoperability with Autodesk companion products as well as an open application programming interface (API).
What’s New
Enhanced Modeling and Collaboration Capabilities
Integrate more efficiently between Autodesk Robot Structural Analysis Professional
and Autodesk Revit Structure.
New approach to building structures with the added ability to create objects such as
beams columns, and walls in lieu of bars and panels.
Import DXF™/DWG files as a drawing background, making it possible to define 3D
structural models on the basis of architectural plans and elevations.
More Improved Design and Analysis Experience
New harmonic and damping analysis parameters have been added, as well as a more
improved and amended footfall analysis.
New national reinforcement, load combination and steel codes have been
implemented into the application, as well as regional codes for Sweden, Australia and
Italy.
Greater Usability
Enhanced creation of load distributions allows users to better analyze load distribution
to beams, columns and walls.
Work more easily with improved, user-friendly steel connections definitions, with
updated dialog boxes.
Work more easily with Eurocode safety factors with a comprehensive dialog box that
contains all Eurocodes available in the program and an additional user-defined set of
parameters.
μολις πηραμε το 2009 , βγαζουνε το 2010. Κατα τον Απριλιο μαλλον. Βλεπω να θελουν αλλα 1000€ για την αναβαθμιση ( η το subscription ). Μαλλον σ'αυτη την εκδοση θα ειναι και τα ελληνικα...
Οποιος έχει σημειώσεις ή απαντήσεις σε ερωτήσεις που έκανε παλιότερα για την χρήση του προγράμματος μπορεί αν θέλει να τα ανεβάσει κάπου (π.χ. rapidshare ....) για να μπορέσουμε όλοι να βοηθηθούμε. Ευχαριστώ....
Δεν τα έχει κανείς σε pdf? Νομίζω έδινε και κάποιες σημειώσεις όταν παρακολουθούσες σεμινάρια.
Πέτρο σου έστειλα κάποια pdf στα Ελληνικά.Πιθανόν ο Μαραβέας να έχει και άλλα.Αυτά μου τα είχε στείλει κατόπιν τηλεφωνικής ερώτησης.
Στο dvd εγκατάστασης έχει κάποια manual στα Αγγλικά.
Tώρα είδα το αρχείο που ανέβασε o paktomenos.Έχει περισσότερα από αυτά που έχω.
Σου έστειλα και τα παλιά manual στα Αγγλικά.
Στην ιστοσελίδα για το robot υποτίθεται ότι έχει demo έκδοση του προγράμματος για την απόκτηση της οποίας απαιτείται κωδικός. Έχω στείλει μέχρι στιγμής δύο mail ζητώντας να μου στείλουν κωδικό και έχω φάει άκυρο και τις δύο φορές. Έχει κατεβάσει κανένας την έκδοση; Ισχύει αυτό που γράφουν ή είναι κάτι που έχει ξεχαστεί στο site τους;
